Netflow sampling rate on C6807-XL, how to inform the collector
lamprop
I am using netflow and trying to inform the flow collectors about the sampling rate I am using.
I added the following commands:
Router(config)#flow exporter xFlow
Router(config-flow-exporter)#template data
Router(config-flow-exporter)#option sampler-table
So the config now looks like:
Router#sh flow exporter xFlow
Flow Exporter xFlow:
  Description:              Exports flows to flow collector
  Export protocol:          NetFlow Version 9
  Transport Configuration:
    Destination IP address: xxxx
    Source IP address:      yyyy
    Source Interface:       Loopback0
    Transport Protocol:     UDP
    Destination Port:       2055
    Source Port:            64759
    DSCP:                   0x0
    TTL:                    255
    Output Features:        Not Used
  Options Configuration:
    exporter-stats (timeout 600 seconds)
    sampler-table (timeout 600 seconds)
And what I have managed until now is the following:
sh flow exporter templates
  Client: Flow Monitor nflow
  Exporter Format: NetFlow Version 9
  Template ID    : 268
  Source ID      : 3
  Record Size    : 47
  Template layout
  _____________________________________________________________________
  |                 Field                   |  Type | Offset |  Size  |
  | ipv4 source address                     |     8 |     0  |     4  |
  | ipv4 destination address                |    12 |     4  |     4  |
  | interface input snmp                    |    10 |     8  |     4  |
  | transport source-port                   |     7 |    12  |     2  |
  | transport destination-port              |    11 |    14  |     2  |
  | ip tos                                  |     5 |    16  |     1  |
  | ip protocol                             |     4 |    17  |     1  |
  | transport tcp flags                     |     6 |    18  |     1  |
  | timestamp sys-uptime first              |    22 |    19  |     4  |
  | timestamp sys-uptime last               |    21 |    23  |     4  |
  | interface output snmp                   |    14 |    27  |     4  |
  | counter bytes long                      |     1 |    31  |     8  |
  | counter packets long                    |     2 |    39  |     8  |
  Template ID    : 269
  Source ID      : 3
  Record Size    : 47
  Template layout
  Client: Option options sampler-table
  Template ID    : 270
  Source ID      : 3
  Record Size    : 51
  Template layout
  | v9-scope system                         |     1 |     0  |     4  |
  | flow sampler                            |    48 |     4  |     4  |
  | flow sampler name                       |    84 |     8  |    40  |
  | flow sampler algorithm export           |    49 |    48  |     1  |
  | flow sampler interval                   |    50 |    49  |     2  |
  Client: Option options exporter-statistics
  Template ID    : 271
  Source ID      : 3
  Record Size    : 32
  Template layout
  | flow exporter                           |   144 |     4  |     4  |
  | counter bytes exported                  |    40 |     8  |     8  |
  | counter packets exported                |    41 |    16  |     8  |
  | counter flows exported                  |    42 |    24  |     8  |
As you can see it reports the field "flow sampler interval" but I don't get the information of sampling rate on the collected flows. I tried with tcpdump also and get only the following:
Please any help.
can you provide an example of what output you are looking for (and what 'show' command you are using) ?
As you can see at the first post I am using the following commands:
show flow exporter
show flow exporter templates
I would like to send the flows with the information of the sampling rate I am using. I would like something similar with this post.
But when I do tcpdump on the packets there is no reference of the sampling rate:
