12-31-2019 06:03 AM - edited 01-01-2020 03:52 AM
i have a cisco 3850 switch....i config netflow input and output ...but netflow tool only show ingress flow detail , no show egress flow details, egress only show total flows , and no show flow detail.... do you have any advise???
<<<screen shot is the bottom>>>
IOS version : 03.07.05E
dervice license : ip service
my configuration is:
flow exporter netflow2428
destination 172.24.24.28
source Vlan230
transport udp 9996
flow record input
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect interface output
collect counter bytes long
collect counter packets long
collect timestamp absolute first
collect timestamp absolute last
flow record output
match flow dir
match ipv4 protocol
match ipv4 tos
match interface output
collect interface input
collect transport tcp flags
collect counter bytes layer2 long
flow monitor input
cache timeout active 60
record input
flow monitor output
record output
interface GigabitEthernet1/1/2
description To SCC Office
no switchport
ip flow monitor input input
ip flow monitor output output
ip address 192.168.242.219 255.255.255.248
no ip redirects
no ip proxy-arp
ip ospf network point-to-point
ip ospf cost 10
ip policy route-map SCS/SCCHKP/VS-to-CT/AWSDEV-PBR
load-interval 30
speed nonegotiate
end
12-31-2019 08:11 AM - edited 12-31-2019 08:15 AM
try to understand from this link . this link has everything that you need to make your config running...
01-01-2020 02:53 AM
01-01-2020 05:38 PM
ohh okkk ... then try this link .. select your specific switch model .. and try to understand the configuration guide or specific command in the reference whether you entered it right or not ...
01-01-2020 05:59 PM
anybody have any advise ??
