netflow V9 (FNF) on ISR 4331 - The monitor does not have a valid record
Alex Willoughby
im getting the error "The monitor does not have a valid record" as per the below when trying to assign my flow monitor to an interface. is anyone Able to shed any light? from what ive researched I cant see any issue with it
config:
STR-LAB-01-RTR-01(config-flow-record)#do sh run | s Sola
flow record FR_Solarwinds
 match ipv4 tos
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 match interface input
 collect interface output
 collect counter bytes
 collect counter packets
 collect timestamp sys-uptime first
 collect timestamp sys-uptime last
 collect application name
flow exporter FE_Solarwinds
 destination 10.66.56.91
 source Vlan5
 transport udp 2055
 option interface-table
 option application-table
flow exporter FW_Solarwinds
flow monitor FM_Solarwinds
 cache timeout inactive 10
 statistics packet protocol
 statistics packet size
STR-LAB-01-RTR-01(config-flow-record)#int vlan 5
STR-LAB-01-RTR-01(config-if)#ip flo
STR-LAB-01-RTR-01(config-if)#ip flow mon
STR-LAB-01-RTR-01(config-if)#ip flow monitor FM_Solarwinds in
STR-LAB-01-RTR-01(config-if)#ip flow monitor FM_Solarwinds input
% Flow Monitor: Failed to add monitor to interface: The monitor does not have a valid record
Alex Willoughby
found the typo, I hadn't applied the record to the monitor
Alex Willoughby
