Highlighted
Netflow wont do anything - me3800x
not sure if the ME3800X is currently supported for netflow?  It takes the commands ok but we cannot get export:
lonppe01#show ip flow interface
GigabitEthernet0/3
  ip route-cache flow
  ip flow ingress
  ip flow egress
lonppe01#show ip flow ex
Flow export v1 is enabled for main cache
  Export source and destination details :
  VRF ID : Default
    Source(1)       10.255.255.4 (Loopback0)
    Destination(1)  10.255.65.20 (9090)
  Version 1 flow records
  0 flows exported in 0 udp datagrams
  0 flows failed due to lack of export packet
  0 export packets were sent up to process level
any ideas?
Many thanks
Nicholas
1 REPLY 1
Highlighted
Beginner
Hi Nicholas,
The Cisco feature navigator shows ME3800 with IOS 15.xx supports NetFlow export but configuration guide for the device does not show any NetFlow commands. Check the below link for the feature navigator:
http://tools.cisco.com/ITDIT/CFN/Dispatch?act=rlsSelect&task=search&searchby=platform.
I dont see ME3800X in the above list and so I selected ME3800 from the platform list.
Just to try, Can you use the below commands and check how it goes:
ip flow-export version 5
ip flow-cache timeout active 1
ip flow-cache timeout inactive 15
And also, enable NetFlow on all your L3 interfaces. NetFlow v1 is not used anymore and the reason to change active flow timeout is because all your network conversations may be long lived ones and thus will ge exported only after they expire.
If it still does not work, I suggest asking Cisco TAC if NetFlow is supported on the device.
Don Thomas Jacob
www.netflowanalyzer.com
NOTE: Please rate posts and close questions if your query has been answered
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
Content for Community-Ad
