Network Assistant Credential Management
Dennis Nielsen
I use CNA 6.0 to give me an overview of our network, but I have a few small problems.
I am in the process of changing access credentials on the switches, but something has gone wrong with my Catalyst 4510E
I wasn't able to change the stored credentials for the 4510 (I use CCO to store credentials) so I deleted the device from the community, but now when I try to add it back in, I just get an Authentication Failed error message, I don't get n option to update the credentials. I am guessing the device wasn't removed correctly from the CCO crdentioal store, how can I do this?
On another device where I changed the credentials, everytime I open CNA I am asked if I want to update the stored credentials, I answer Yes and type in the updated credantials, but next time I load CNA, I am asked again.
How can these problems be solved?
0 Replies 0
