Network design redundancy advice
RBeugnies
Hi all,
I have a network which requires redundancy. I need to have 2 firewalls and 2 distribution switches.
I have come up with a design idea however I’m not sure if this is the correct way to achieve the desired results, but with that said from my knowledge I believe it should work.
I would appreciate any comments or alternative design ideas.
Dennis Mink
This looks OK, as a physical/layer 1 redundancy.
you would need to add a similar diagram for layer 2 (VLANs)
and layer 3 (ip interfaces, subnets and what routing you are going to use, or potentially set the FWs up as an HA pair).
Please remember to rate useful posts, by clicking on the stars below.
