Network Design
msaeed
i am designing a new architecture for my network. i have the below devices and network component
  • ISR 4331 router
  • 2 core switch C9470
  • 2 cisco firewall 1150
  • CT3504 wireless controller
  • and access switches 9300 and 9200
  • i will have around 5 internet fiber lines
  • servers for  LAN and servers will be accessed from the internet
  • around 20 VLAN
what is the best practice design for my network?
5 Replies 5
Mark Elsen
 - Note , in essence this isn't really a question for the forum , which targets 'short-lived' practical and technical questions. In that context you can better work with a re-seller or integrator for solid advice. That costs money indeed, but you will also create a stronger case for your business and you handoff responsibilities somewhat.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
i already have re-seller. but I am afraid that the design they suggested is not the best practice. therefor i am seeking the experts advice here
Without knowing a lot about this network there is not a lot to say other than "engage a reputable system integration".
Sure, the list of equipment is nice but "what are you trying achieve" is the best question that needs to be asked.
         - What design was suggested , why did you not like it ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
  • they connected the internet direct to the firewall. router removed
  • the make firewall the default gateway for all VLAN. all routing on the firewall
