Hi, wondering which NMS that people are using. We have around a 100 networks devices, WLC, NetScaler and FMC/FTD. We currently use Cisco Prime Infrastructure but are hoping to find a more encompassing tool that would provide alerting, config backup/archive and performance monitoring.
Couple of them do your job :
Solarwinds.
ManageEngine
PRTG
Many Opensource -Free (need to put some effort, all done for you)
Zabixx
Hi, we already use SolarWinds for mostly server monitoring. We are going to install the Network Configuration Module to see what we get from that.
Hi, we also have DNAC. It doesn't archive configurations.
Hi.
For smaller networks, I'm using LoriotPro (luteus.fr or loriotpro.com). Easy to install, easy to use an not really expensive.
In other cases, I'm using PRTG. Also a nice tool.
Best regards
Markus
