Nexus 5548 NTP Problem
Mate Grbavac
Beginner
Beginner
I have problem with syncing Nexus and NTP server.
MGMT IP adress of Nexus is 10.24.130.137 and address of NTP server is 10.242.32.12, there is full routing and NTP reachbility between Nexus and NTP but Nexus is unsynced:
N5k-04-A# sh ntp peer-status
Total peers : 1
* - selected for sync, + -  peer mode(active),
- - peer mode(passive), = - polled in client mode
    remote               local                 st   poll   reach delay
=10.242.32.12           10.24.130.137           2   16     377   0.00310
Config of NTP is:
N5k-04-A# sh run ntp
!Command: show running-config ntp
!Time: Wed Apr 10 14:41:35 2013
version 6.0(2)N1(2)
ntp server 10.242.32.12 use-vrf management
ntp source-interface  mgmt0
ntp logging
I captured traffic with wireshark and see something strange in NTP Packet: "Reference ID: Unindentified reference source '...'"
I have one Catalyst 2960 on same subnet and it's syncronized with same NTP without any problems.
Here is snapshot of wireshark capture:
P.S. Don't bother about malformed packet, it's probably because of using ERSPAN.
ngoldwat
Enthusiast
Enthusiast
First, what do you get when running
     sh run | i clock
Do you have 'clock protocol ntp' configured?
Otherwise, what are the output results for:
    sh ver
    sh run ntp
    sh ntp peer-status
Mate Grbavac
Beginner
Beginner
It's a bug.
Workarond is to disable and then enable feature ntp.
N5k-06-A(config)# no feature ntp
N5k-06-A(config)# feature ntp
N5k-06-A(config)# end N5k-06-A(config)# no feature ntp
Recognize Your Peers
