i want monitored the status of nexus7010.(Mainly Includes:cpu、memory and temperature information). I can't use oid for my nms which downloaded from the cisco website. So I need some advices
.1.3.6.1.2.1.47.1.1.1.1.2
entPhysicalIndex OBJECT-TYPE
-- FROM ENTITY-MIB
-- TEXTUAL CONVENTION PhysicalIndex
SYNTAX Integer (1..2147483647)
MAX-ACCESS not-accessible STATUS Current
DESCRIPTION "The index for this entry."
This OID will help you to get each module value.
.1.3.6.1.4.1.9.9.91.1.1.1.1.4
entSensorValue OBJECT-TYPE
-- FROM CISCO-ENTITY-SENSOR-MIB
-- TEXTUAL CONVENTION SensorValue
SYNTAX Integer (-1000000000..1000000000)
MAX-ACCESS read-only
STATUS Current
DESCRIPTION "This variable reports the most recent measurement seen
by the sensor.
