468
Highlighted
Beginner
Nexus 7K limited config role
I need to create a role in a 7K version 6.2(16) for a server admin to be able to add and remove one variation of a route (in the middle of the night, so I don't want to get up unless he calls me if it all goes wrong).
The commands he needs to be able to execute are:
ip route 10.11.20.23/32 10.10.10.26 tag 10
ip route 10.11.20.23/32 10.10.10.27 tag 10
no ip route 10.11.20.23/32 10.10.10.26 tag 10
no ip route 10.11.20.23/32 10.10.10.27 tag 10
I fiddled with roles a little, but it's not straightforward how to make this happen. Here's what I have:
role name serveradmin
rule 10 permit command config t
rule 1 permit command ip route 10.11.20.23/32 10.10.10.2[67] tag 10
rule 2 permit command no ip route 10.11.20.23/32 10.10.10.2[67] tag 10
It said it supported regex, so I figured I'd just go for that.
Once I go into "config t"I don't have any options. I'm guessing "command" means exec mode and doesn't count for config mode. However, I don't see a way to do anything for config mode besides read-write features, ip routing not being one of those. Any suggestions?
Everyone's tags (2)
Content for Community-Ad
July's Community Spotlight Awards
