07-19-2021 11:03 PM
Dear Team,
Kindly help to find the root cause of Nexus 9K C93180YC-FX Device Unsupported error showing on Cisco Prime Infra 3.4, however, Nexus 9K 9508 device has no error.
Solved! Go to Solution.
07-20-2021 12:28 AM
- Guess bad news :
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg25220/?rfs=iqvred
M.
07-20-2021 01:16 AM
I had a look at both PI Compatibility Matrix and DNAC Compatibility Matrix and I cannot find any mention of a 93180 anywhere.
07-19-2021 11:35 PM
Is the Device Pack up to the latest version?
07-19-2021 11:49 PM
No, @Leo Laohoo Current both devices ( Nexus 9K C93180YC-FX & 9508) image version is version 7.0(3)I7(8).
07-19-2021 11:53 PM
- Leo refers to Device Packs, which sometimes must be added/installed to an existing Prime installation (version) to support new devices, however , you may however need a more recent Prime version , all info in :
M.
07-19-2021 11:35 PM
Look up your device , check for Prime version , supported for the first time.
M.
07-20-2021 12:28 AM
- Guess bad news :
M.
07-20-2021 01:16 AM
07-21-2021 11:12 PM
In some previous years, I think this model was supported but is currently unsupported. But not an issue thanks to all @marce1000 @Leo Laohoo for your prompt supports and reply.
