nexus dcnm snmpv3 with aaa authetication
patcbr600
Hi all,
I have enable aaa on my nexus switch, the user that i use for authentication is getting the default privileges, in the nexus config the dcnm configure a snmp-user with the role vdc-operator, since the dcnm needs vdc-admin how can i change the snmp-user on the nexus to have the vdc-admin role.
thanks
Vinod Arya
Which Nexus model you have? You can try to configure snmp user with vdc-admin syntax which should make it admin:
snmp-server user admin vdc-admin xxxxxxx (followed by other parameters)
Please check.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Nexus 7710.
Hi already have put that command but dcnm also the same command with network-operator since the user that the dcnm user is authenticated via tacas with the default role network-operator.
On the show snmp user i see the same user with vdc-admin and network-operator role
