09-05-2016 02:55 PM
Good Day All,
I have configured tacacs+ & aaa configuration on my nexus but it is not working anyonen can advice with expert opinion?? below are configs done:
AAA Configurations
HQ-N7K-2# sh running-config aaa
aaa authentication login default group PACI-TACACS
aaa authentication login console local
aaa authorization config-commands default group PACI-TACACS local
aaa authorization commands default group PACI-TACACS local
aaa accounting default group PACI-TACACS
no aaa user default-role
tacacs-server directed-request
TACACS+ Configurations
HQ-N7K-2# sh running-config tacacs+
feature tacacs+
tacacs+ distribute
ip tacacs source-interface mgmt0
tacacs-server host 172.10.1.100 key 7 "paci@XXX"
tacacs+ commit
aaa group server tacacs+ PACI-TACACS
server 172.10.1.100
use-vrf management
Connectivity towards ACS Server
HQ-N7K-2# ping 172.10.1.100 source 172.17.1.114 vrf management
PING 172.17.1.100 (172.17.1.100) from 172.17.1.114: 56 data bytes
64 bytes from 172.10.1.100: icmp_seq=0 ttl=63 time=1.258 ms
64 bytes from 172.10.1.100: icmp_seq=1 ttl=63 time=1.154 ms
64 bytes from 172.10.1.100: icmp_seq=2 ttl=63 time=1.186 ms
64 bytes from 172.10.1.100: icmp_seq=3 ttl=63 time=1.349 ms
64 bytes from 172.10.1.100: icmp_seq=4 ttl=63 time=1.226 ms
Port (49) testing towards ACS
HQ-N7K-2# telnet 172.10.1.100 49 source 172.17.1.114 vrf management
Trying 172.10.1.100...
Connected to 172.10.1.100.
Escape character is '^]'.
Connection closed by foreign host.
but on testing I am getting this.
HQ-N7K-2# test aaa group PACI-TACACS aashfaque 12345698
error authenticating to server, status=7
Please advice if you see any issue in configs....
Solved! Go to Solution.
09-12-2016 03:39 PM
Step 1 was already there, Step 2 I added IP of Nexus with tacacs key & Step 3 Pls see attached.
Many thanks for support.
09-12-2016 04:09 AM
As you have used command authorization on Nexus.
Are you pushing privilege 15 from Nexus with command set full access.
Could you please confirm.
Gagan
09-12-2016 07:21 AM
Thanks Bro,
I have config below command:
username admin password 5 $1$O8eLTVET$QbHdUsawG6Lv7hIdIT29m1 role network-admin
Else tell me output you are priorlly looking for?
09-12-2016 09:00 AM
Hi Ahmed,
I am looking for shell profile and command set configured on tacacs server for Nexus.
Please get both screen shots :
Cisco Secure ACS
Policy Elements > | ... > | Authorization and Permissions > | Device Administration > | Shell Profiles |
Cisco Secure ACS
Policy Elements > | ... > | Authorization and Permissions > | Device Administration > | Command Sets |
Gagan
09-12-2016 12:29 PM
09-12-2016 12:55 PM
Hi Ahmed,
Firstly, Try to reset the shared secret configured on both Nexus and ACS. Remove tacacs commit and distribute for testing.
On Nexus
On ACS
Network resources > Network devices > look for nexus IP.
Then click on tacacs and change the key.
Secondly,
please share screenshot of rule created on Authorization.
Under Access policy > Default device administration
Let me know identity group and authorization rule in use.
Gagan
09-12-2016 03:39 PM
09-13-2016 03:15 AM
Hi Ahmed,
I would suggest in this case to remove aaa commands and tacacs group from Nexus
Do it from scratch.
!--- Enable TACACS+ on the device.
feature tacacs+
tacacs-server host 10.0.0.1 key 7 Cisco
tacacs-server host 10.0.0.2 key 7 Cisco
!--- Provide the name of your ACS server.
aaa group server tacacs+ ACS
!--- Mention the IP address of the tacacs-servers
server 10.0.0.1
server 10.0.0.2
use-vrf management
Commands to check the Tacacs or Radius configuration & command to test the aaa server group.
> Command: show running-config tacacs+ all
> Test the TACACS server availability:
test aaa group group-name username password
Create user and define AAA client as Nexus in ACS
then test it again. If user is authenticating then only put aaa commands.
If request not reaching then do # ping 10.25.32.80 vrf management
You can enable following debugs to check rest of the issues:
Debug aaa all
Debug tacacs+ all
Debug radius all
Gagan
PS: rate if it helps!!!!
09-14-2016 02:10 PM
Hey Ahmed,
Did you try the action plan provided.
Gagan
09-14-2016 04:08 PM
Hello Boss,
All the listed commands are there...it does ping to ACS (from nexus) and does telnet on port 49 too but does not authentication user.
