NME-AIR-WLC config fetch fails RME 4.2
chharris41
I am having problems with the config fetch on the NME-AIR-WLC8-K9 running 5.1.151.0. I am using telnet, not ssh so the bug documented for other wlc's doesn't apply. I've checked/re-checked credentials, I can telnet fine to the device but config fetch fails (however inventory collection does work). I have installed all of the relevant device updates.
Please let me know if you have any ideas on this.
5 Replies 5
Joe Clarke
Enable ArchiveMgmt Service debugging under RME > Admin > System Preferences > Application Loglevel Settings, repeat the job, and post the dcmaservice.log.
Ok - log file is attached.
This device does not appear to be supported for configuration yet. What is its sysObjectID?
OID:1.3.6.1.4.1.9.1.818
Yes, this particular WLC is not yet supported in RME 4.2. There is currently no ETA on when support will be available.
