NMS for Cisco-2960l switches
Mesrop
Hello friends.
Please suggest me NMS for cisco 2960-L switches,with desktop view.
balaji.bandi
Many available Like PRTG (certail level its free to use)  - how many devices you like to Monitor
and you looking to install on your PC ?
BB
balaji.bandi
BB
Thanks my freind,up to 70 devices.
Yes i want to install it on my PC.I`v tried to use CNA,but there is not support for Cisco 2960-L.
Is there other tool beside PRTG?
On PC with 70 device may be more i guess, if you have dedicated PC or Server want to use Opensource Linux based many available ( again depends how depth knowledge you have on Linux and Monitor tools)  PRTG is easy to clicks so i suggested,
you can find good free tools below :
https://www.networkstraining.com/best-open-source-free-network-monitoring-tools/
BB
Thank you.
I started use PRTG monitor,thanks for your suggestion.
