No http access to 2960-24TC-L running lanbasek9-mz.150-2.SE6
Elton Closs
I cannot http/https to this switch however I can ssh to this switch with no problem. I read online about an html folder in flash which this does not have but neither do the 5 other switches I tested and all of them worked. I have @ 160 various model 2960s all work fine but this one. I normally don't use http but Cisco Network Assistant requires it.  Any ideas ??
ghostinthenet
Level 7
Level 7
What happens when you attempt to connect with HTTP/HTTPS? If you do a "show running-config | include ip http" from the CLI of a switch, what kind of results do you get?
When I did this I got just what all the other switches show but I saw an ACL which I then looked at and it had a typo in it. I corrected the problem and now I can SSH and HTTP into the switch. Thanks for pointing me in the right direction.
Glad to hear! Please rate and/or mark any comments that you found helpful as correct.
