No internet connection
PFredriks
i'm doing a project for school and we are using a Cisco 2950 switch and a Cisco 2800 series router. I have configured some settings but i can't get a connection to the internet, through the switch. I can send a ping from the router to for example google.com, this works!
Switch configuration:
Building configuration...
Current configuration : 2009 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
 switchport mode trunk
interface FastEthernet0/2
 switchport access vlan 100
 switchport mode access
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
 switchport trunk native vlan 100
 switchport trunk allowed vlan 100,150,200,250
interface Vlan1
 no ip address
 no ip route-cache
 shutdown
ip default-gateway 10.1.0.1
ip http server
line con 0
line vty 0 4
 login
line vty 5 15
 login
end
Router Configuration:
Current configuration : 1904 bytes
! Last configuration change at 11:17:22 UTC Tue Jun 3 2014
version 15.0
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
redundancy
interface FastEthernet0/0
 ip address 10.1.0.1 255.255.255.0
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
 no ip address
 ip nat inside
 duplex auto
 speed auto
interface FastEthernet0/1.10
 encapsulation dot1Q 10
 ip address 10.10.0.1 255.255.255.0
interface FastEthernet0/1.100
 encapsulation dot1Q 100
 ip address 10.100.0.1 255.255.255.0
interface FastEthernet0/1.150
 encapsulation dot1Q 150
 ip address 10.150.0.1 255.255.255.0
interface FastEthernet0/1.200
 encapsulation dot1Q 200
 ip address 10.200.0.1 255.255.255.0
interface FastEthernet0/1.250
 encapsulation dot1Q 250
 ip address 10.250.0.1 255.255.255.0
interface Serial0/0/0
 no ip address
 shutdown
 no fair-queue
 clock rate 125000
interface Serial0/0/1
 no ip address
 shutdown
 clock rate 125000
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip route 0.0.0.0 0.0.0.0 10.1.0.254
access-list 1 permit 10.10.0.0 0.0.0.255
access-list 1 permit 10.100.0.0 0.0.0.255
access-list 1 permit 10.150.0.0 0.0.0.255
access-list 1 permit 10.9.15.0 0.0.0.255
access-list 1 permit 10.1.0.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
 login
scheduler allocate 20000 1000
end
The IP address (10.1.0.254) used by the static default route is a Sonicwall which is placed between the router and the wall-outled.
I hope somebody can help me with this problem.
Kind regards,
Patrick
Hi ,
 You have missed ip nat inside on your sub-interface , kindly define it should be working .
 ip nat inside
 ip nat inside
 ip nat inside
 ip nat inside
 ip nat inside
Sandy
Hi ,
 ip nat inside
 ip nat inside
 ip nat inside
 ip nat inside
 ip nat inside
Sandy
Thanks Sandy,
This worked out great for me!
Sadly the button for  Correct Answer doesn't work, it sends me to a site where i don't have access to.
But thank you very much!
