I am attempting to upgrade a Catalyst 3560 v2 Series PoE-48 from an older Catalyst 3560. I have upgraded the new Cat to IOS 12.2(55) and copied the running-config over.
When comparing the old running-config to the new running-config I discovered that
ip sla enable reaction-alerts
is turned on automatically. As this uses memory and could be a potential form of overhead as we don't use it, I would like to turn it off.
The command
no ip sla enable reaction-alerts
Has no effect: See here below. I have removed the MAC address and the standard texts from the show version.
Is this a bug or am I missing something in order to turn this unwanted (at the moment) functionality off.
=== output ===
G877_S49#show version
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(55)SE1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 02-Dec-10 07:17 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(53r)SEY1, RELEASE SOFTWARE (fc1)
G877_S49 uptime is 1 hour, 54 minutes
System image file is "flash:/c3560-ipservicesk9-mz.122-55.SE1/c3560-ipservicesk9-mz.122-55.SE1.bin"
cisco WS-C3560V2-48PS (PowerPC405) processor (revision L0) with 131072K bytes of memory.
Processor board ID FDO1511V1TU
Last reset from power-on
3 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 40:55:39:xx:xx:xx
Motherboard assembly number : 73-12630-01
Power supply part number : 341-0266-03
Motherboard serial number : FDO15120H0M
Power supply serial number : DCA1504HGDG
Model revision number : L0
Motherboard revision number : B0
Model number : WS-C3560V2-48PS-E
System serial number : FDO1511V1TU
Top Assembly Part Number : 800-33978-01
Top Assembly Revision Number : D0
Version ID : V06
CLEI Code Number : COMKX00DRB
Hardware Board Revision Number : 0x02
Switch Ports Model SW Version SW Image
* 1 52 WS-C3560V2-48PS 12.2(55)SE1 C3560-IPSERVICESK9-M
Configuration register is 0xF
G877_S49#show running-config | include reaction
G877_S49#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
G877_S49(config)#no ip sla enable reaction-alerts
G877_S49(config)#^Z
G877_S49#
*Mar 1 01:55:06: %SYS-5-CONFIG_I: Configured from console by console
G877_S49#
=== end output ===
Re: Ciscoworks showing + and - when running a compliance check
Also the no ip sla enable reaction-alerts command is not removing this from the configuration.
