no ip sla enable reaction-alerts on Cisco Catalyst 3560 vs IOS 12.2(55)SE1 does not disable reaction alerts
damion
I am attempting to upgrade a Catalyst 3560 v2 Series PoE-48 from an older Catalyst 3560. I have upgraded the new Cat to IOS 12.2(55) and copied the running-config over.
When comparing the old running-config to the new running-config I discovered that
is turned on automatically. As this uses memory and could be a potential form of overhead as we don't use it, I would like to turn it off.
The command
Has no effect: See here below. I have removed the MAC address and the standard texts from the show version.
Is this a bug or am I missing something in order to turn this unwanted (at the moment) functionality off.
=== output ===
G877_S49#show version
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(55)SE1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 02-Dec-10 07:17 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(53r)SEY1, RELEASE SOFTWARE (fc1)
G877_S49 uptime is 1 hour, 54 minutes
System image file is "flash:/c3560-ipservicesk9-mz.122-55.SE1/c3560-ipservicesk9-mz.122-55.SE1.bin"
cisco WS-C3560V2-48PS (PowerPC405) processor (revision L0) with 131072K bytes of memory.
Processor board ID FDO1511V1TU
Last reset from power-on
3 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 40:55:39:xx:xx:xx
Motherboard assembly number     : 73-12630-01
Power supply part number        : 341-0266-03
Motherboard serial number       : FDO15120H0M
Power supply serial number      : DCA1504HGDG
Model revision number           : L0
Motherboard revision number     : B0
Model number                    : WS-C3560V2-48PS-E
System serial number            : FDO1511V1TU
Top Assembly Part Number        : 800-33978-01
Top Assembly Revision Number    : D0
Version ID                      : V06
CLEI Code Number                : COMKX00DRB
Hardware Board Revision Number  : 0x02
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3560V2-48PS    12.2(55)SE1           C3560-IPSERVICESK9-M
Configuration register is 0xF
G877_S49#show running-config | include reaction
G877_S49#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
G877_S49(config)#no ip sla enable reaction-alerts
G877_S49(config)#^Z
G877_S49#
*Mar  1 01:55:06: %SYS-5-CONFIG_I: Configured from console by console
G877_S49#
=== end output ===
damion
On Aug 6, 2010 another Cisco customer also noticed this behaviour, but his thread was on another topic so this message got missed by the Cisco Employee helping.
9. Aug 6, 2010 8:32 AM in response to:        AJ Reid
Re: Ciscoworks showing + and - when running a compliance check
Also the no ip sla enable reaction-alerts command is not removing this from the configuration.
