07-23-2013 06:24 AM
Please tell me how to restore the display of important events?
One no longer displayed.
Monitor> Monitoring Tools> Fault Monitor
Syslog when it works, generate new posts.
The menu "Admin" has a message:
Critical Message Window
Ciscoworks Drive Utilization
C:/PROGRA~2/CSCOpx 65%
Processes EPMServer are down
All services LMS is running in operate system.
What information may still be necessary for the diagnostics?
EPMserver.log
log4j:ERROR Could not connect to remote log4j server at [localhost]. We will try again later.
java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:529)
at java.net.Socket.connect(Socket.java:478)
at java.net.Socket.<init>(Socket.java:375)
at java.net.Socket.<init>(Socket.java:218)
at org.apache.log4j.net.SocketAppender.connect(SocketAppender.java:203)
at org.apache.log4j.net.SocketAppender.activateOptions(SocketAppender.java:160)
at org.apache.log4j.config.PropertySetter.activate(PropertySetter.java:256)
at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:132)
at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:96)
at org.apache.log4j.PropertyConfigurator.parseAppender(PropertyConfigurator.java:654)
at org.apache.log4j.PropertyConfigurator.parseCategory(PropertyConfigurator.java:612)
at org.apache.log4j.PropertyConfigurator.parseCatsAndRenderers(PropertyConfigurator.java:533)
at org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:417)
at org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:441)
at org.apache.log4j.helpers.OptionConverter.selectAndConfigure(OptionConverter.java:470)
at org.apache.log4j.LogManager.<clinit>(LogManager.java:122)
at org.apache.log4j.Category.getInstance(Category.java:519)
at com.cisco.nm.trx.LogService.ItemLog.loadMyLogConf(ItemLog.java:137)
at com.cisco.nm.trx.LogService.ItemLog.<init>(ItemLog.java:87)
at com.cisco.nm.trx.LogService.ItemLog.getInstance(ItemLog.java:203)
at com.cisco.nm.trx.epm.providers.IptmLoggerImpl.<clinit>(Unknown Source)
at com.cisco.nm.trx.epm.Epm.logger(Unknown Source)
at com.cisco.nm.trx.epm.Epm.log(Unknown Source)
at com.cisco.nm.trx.epm.process.EpmMain.main(Unknown Source)
java.lang.NullPointerException
at com.cisco.nm.trx.epm.providers.IptmLoggerImpl.shouldLog(Unknown Source)
at com.cisco.nm.trx.epm.providers.LoggerImpl.log(Unknown Source)
Exception in thread "main" log4j:ERROR Could not connect to remote log4j server at [localhost]. We will try again later.
Exception in thread "main" log4j:ERROR Could not connect to remote log4j server at [localhost]. We will try again.....
08-04-2013 11:51 PM
***UP***
06-25-2019 08:15 AM
I have the same problem but no solution...
