NTP authentication
Ashwini Kumar
I have doubt please help me out with it.
Here is the scenerio :
I have to run NTP, in which one router will act as server and it will update its time from external source, if external source is unreachable then it will act as server of other Routers. we have three Routers which will update there clock from server. But out of those three one Router should authenticate with server and others should not use authenticate method.
For example lets take :
R1 as server and R2,R3 and R4 as client.
R1 and R4 should authenticate.
R1, R2 and R3 should not authenticate.
Ultimatly all Routers should scynchronize.
Note : (You can run any routing protocol and Routers are connected in series connection)
Please provide me the config for the scenerio, I am unable to configure this part
Thank you,
Ashwini Kumar
Ashwini Kumar
Any one please help me....
I am stuck with this part of NTP...
