It is difficult to say how many MIBs are polled by LMS server as it will depend on very server basis. LMS as in background works as individual module for feature classifiaction. And it will depend on what MIBs are used by which module and if that module is enabled in LMS or not.
Like for Campus data that includes Data Collection, end host tracking and topology management features it uses some sets of MIBs which is defined in NMSROOT\campus\etc\cwsi\mibinfo.dat file.
For fault management details of initial snmpwalk is in NMSROOT\objects\smarts\conf\discovery\snmpwalk.conf, but details information on what MIBs are used are mentioned in LMS monitoring and troubleshooting user guide's MIBs Polled section.
For Inventory and Config management, there is no clear details available but the debugtool under
MDC\tomcat\webapps\rme\WEB-INF\debugtools\inventory directory tells what MIBs are mostly needed.
Though these MIB differs device to device and depedning on their OS, as one perticular information via one device may be fetched through X-MIB the same information via Y-MIB.
Some other MIBs which can initially can be used are by device discovery process. It also depends what module you select for discovery which will get devices accordingly, like CDP, ARP, routing table, OSPF, BGP etc.
At last there is health and utilization module which has no limits because you can add any mib to it and poll your own variables to collect results.
So I am not sure what originates your question and why you need a specific detail on MIBs, but giving you exact details need the entire engineering data for LMS, which I think it difficult.
-Thanks
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
