OID for ISDN not recognised
rickd12345
I am trying to monitor the d channel of an isdn wic and have found the following OID in the CISCO-ISDN-MIB :
demandNbrPhysIf 1.3.6.1.4.1.9.9.26.1.1.1.1.1
This would seem ideal but when I enter the details in to our monitoring application (IPCheck) it says there is no such name.
SNMP has been set up correctly on the router and application so I dont understand what the problem could be.
I have 1 wic-1b installed in a 2620xm.
Can someone confirm that this OID should work with this set up or am I way off with what I thinking ?
Also, I am planning to move the isdn card in to a device (Cisco3640) which already has a PRI ISDN30 installed. In this instance, assuming I can get the OID working how do I specify / know which of the D channels will be monitored. Ideally I would want to monitor both....
Any ideas greatly appreciated,
thanks
Richard
David Stanford
The object demandNbrPhysIf is not-accessible so this is why its coming back as no such name.
If you are looking for info on the D channel have you looked at the CISCO-POP-MGMT-MIB which has objects like cpmISDNCfgActiveDChannels.
Are there specifics you are looking for or just overall monitoring of D channel?
