Option to Manage Thresholds in DFM not available
dionjiles
Hi I'm running DFM 3.2.0 and when I tried to expand the tab to manage threshold on interfaces nothing is there.
I tried rebooting the server to see if it fixes the problem no luck.
I am able to expand Device type groups and make changes, not for the DFM or User defined group.
I was able to last week though.
24 Replies 24
dionjiles
To give you an example:
Under DFM>Configuration>Managing Thresholds> I'm able to expand Device Type groups i.e. Routers, Sec. and VPN, etc.
For DFM which has the access port groups and such.....when I click on the expand button nothing shows up.
Joe Clarke
This sounds like it's working by design.  Grouping in DFM is strange, and not like the other applications.  Post a screenshot so I can confirm.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
Attached is a snapshot on my slave server and master server.
This was working earlier this week when I changed High Utilization from 40% to 95%
Not sure why option is not available now.
Yes, that should be working.  Have you tried restarting Daemon Manager on this server yet?
Yes I have.
-Dion
On Apr 9, 2010, at 2:21 AM, "jclarke"
Post the logs under NMSROOT/log/dfmLogs/PTM.
Please see attached.
There appears to be an OGS problem.  Have you tried rebooting the entire server?  You may be seeing a bug where the DfmServer processes don't actually a terminate on Daemon Manager shutdown.  A reboot would confirm that.
That's what I assumed....I have rebooted the server several times.
-Dion
On Apr 12, 2010, at 6:36 PM, "jclarke"
Post the output of:
NMSROOT/objects/smarts/bin/brcontrol
And post the DFMOGSServer.log.
I'm having truoble finding this log file.
DFMOGSSErver.log
Also brcontrol seems to be an application.
Nevermind here is the log file.
I wanted you to run the brcontrol program, and post the output.
Sorry about that.
I ran the program and here is the output located in CSCOpx\log directory.
