Options to bulk add a Voice Vlan to all existing Access ports?
pmanicioto
Hello All,
I will preface this with I do not know much at all about scripting, but I have tinkered in Prime Infrastructure with releasing bulk changes to devices and can do some simple changes fine, but this one is throwing me for a loop and would appreciate some ideas.
I would like to figure out a way to select my range of switches and scripting a way to say something like : If switchport mode = access, then switchport voice vlan *vlan #*
The reason i would like to do this is because the interface numbers change across the environment between models and some are stacked, so it is not %100 continuity in interface names/numbers and I have quite a few hundred switches to change.
If this is at all possible to do a variable type script in Prime like this, or suggestions on something else to use and where to start so I can learn how to configure this, I would appreciate it.
balaji.bandi
get cattools free trial version, easy to push all changes what you looking all devices.
https://www.solarwinds.com/kiwi-cattools
BB
Thank you for the suggestion, however I am not sure how well this will work considering my devices do not follow a typical management IP scheme and would need to discover the devices first.
I may be able to copy/paste the IP's from a spreadsheet in, however the next issue is that some are FA01-24, some are Fa0/1-48, some are GI1/0/1-48, some are Gi1/0/1-36 then TE1/0/37-48, some are stacked and now GI1-2-3-4 ranges which complicates this quite a bit
This is why I was looking for something I can easily do an If/then statement or select ALL ethernet interfaces in bulk on all devices to make the change.
Plus any demos usually have a very small limit of devices to test on because they want to get paid. I already have these devices in Prime and in WhatsupGold for mass changes, just limited to premade templates due to not knowing much about scripting
If you have a writeable snmp community this script can do the job.
#!/bin/bash
community="public"
voicevlan=101
IP=(192.168.0.1 192.168.0.2)
for myip in "${IP[@]}"
do
    echo "$myip"
    # CISCO-VLAN-MEMBERSHIP-MIB::vmVlan = 1.3.6.1.4.1.9.9.68.1.2.2.1.2
    switchports=`snmpwalk -M /dev/null -v 2c -c $community $myip 1.3.6.1.4.1.9.9.68.1.2.2.1.2 2>/dev/null`
    printf "$switchports\n"
    printf "write voice vlans\n"
    for ports in $switchports
    do
        [[ $ports =~ iso.3.6.1.4.1.9.9.68.1.2.2.1.2.([0-9]+) ]]
        index=`echo "${BASH_REMATCH[1]}"`
        # CISCO-VLAN-MEMBERSHIP-MIB::vmVoiceVlanId = 1.3.6.1.4.1.9.9.68.1.5.1.1.1
        snmpset -M /dev/null -v 2c -c $community $myip 1.3.6.1.4.1.9.9.68.1.5.1.1.1.$index integer $voicevlan 2>/dev/null
    done
done
[root@CrashCart mibwork]# ./switchports
192.168.0.2
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10102 = INTEGER: 1
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10105 = INTEGER: 1
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10122 = INTEGER: 1
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10123 = INTEGER: 11
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10125 = INTEGER: 1
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10141 = INTEGER: 1
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10142 = INTEGER: 1
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10143 = INTEGER: 1
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10144 = INTEGER: 11
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10145 = INTEGER: 1
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10149 = INTEGER: 1
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10150 = INTEGER: 1
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10151 = INTEGER: 1
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10152 = INTEGER: 1
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10201 = INTEGER: 1
iso.3.6.1.4.1.9.9.68.1.2.2.1.2.10202 = INTEGER: 1
write voice vlans
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10102 = INTEGER: 101
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10105 = INTEGER: 101
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10122 = INTEGER: 101
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10123 = INTEGER: 101
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10125 = INTEGER: 101
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10141 = INTEGER: 101
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10142 = INTEGER: 101
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10143 = INTEGER: 101
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10144 = INTEGER: 101
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10145 = INTEGER: 101
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10149 = INTEGER: 101
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10150 = INTEGER: 101
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10151 = INTEGER: 101
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10152 = INTEGER: 101
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10201 = INTEGER: 101
iso.3.6.1.4.1.9.9.68.1.5.1.1.1.10202 = INTEGER: 101
The first for loop identifies if it is access port and the second for loop writes the voicevlan number as 101.
Thank you greatly. I will see if I can manipulate this into a template in prime and make it work.
