04-10-2019 11:34 PM
I'm ccna student. And on the routers in our class if you command show flash: to me they look polluted.
I dont know if the output is normal? Does a default out of box router/switch has so much crap in its directory?
On some routers in our class, there are over 400 files on the flash.
Can you tell me something more about the output? What happend probably. Their many new students who experiment with these routers. Maybe its time they all need a clean up.
Thank you for reading and maybe answering.
Solved! Go to Solution.
04-11-2019 12:06 AM
@Appelsapje wrote:
so the output is normal?
Is the output normal? Yes.
Would I use it? I wouldn't touch it.
If you're studying for CCNA, CCP isn't going to be much of any help.
04-10-2019 11:45 PM
04-10-2019 11:52 PM
04-11-2019 12:06 AM
