Packet Tracer Trouble
Sanjay916
Hello, I am trying to solve this network but I don't understand 2 of these instructions.
- Configure all redundant links between Switch0 and Switch1 as an etherchannel
- Configure all Trunks to allow only Vlan traffic for the vlans in the topology
Anyone has any ideas of how I can configure this properly? I provided a screenshot of the network topology. Please help.
Martin L
it looks like your Etherchannel config is not correct since STP blocking 2 and allowing 1 link;
Please share your config here; just the part that includes those trunks between switches and Etherchannel  config
Regards, ML
**Please Rate All Helpful Responses **
Thank you for replying. Included a packet tracer file and also a configuration script of the network. The areas that's  highlighted in red are the ones that I am unable to configure. Thanks
Martin L
To make etherchannels work, add following config:
interface FastEthernet0/3
channel-group 1 mode on
interface FastEthernet0/4
interface FastEthernet0/5
Note: those will allow all vlans
Regards, ML
