08-05-2005 02:43 AM
I have problems stopping the Ciscoworks services. The dmgtd stop doesn't work well and pdshow doesn't work.
It's a new LMS2.2 installation coming from a 2.2 to 2.5 upgrade, uninstallation of 2.5 and installation of 2.2.
Any idea??
08-05-2005 03:00 AM
hi...
infact the command to stop Ciscoworks services is not dmgtd try this command instead
'net stop crmdmgtd' this will stop the ciscoworks services ,and try 'pdshow |more ' command from the Ciscoworks install folder..assuming u r running Ciscoworks on a windows server..
cheers
shiju..
08-05-2005 03:05 AM
Sorry,
it's a Solaris 2.8
08-05-2005 07:30 AM
I have a similar problem ("dmgtd stop" timing out) on a particular lab box, after RME 3.5 IDU 10 and CM 3.3 IDU 10 on LMS 2.2. Here's a not-very-elegant workaround I used to get IDUs 11 installed, may or may not suit your purpose:
- temporarily disable "/etc/rc3.d/S10dmgtd" (and "/etc/rc3.d/S93ipm", if you have RWAN 1.x) by renaming it to something else
- reboot your box
- do whatever you need to do with dmgtd stopped here
- when finished, reinstate "/etc/rc3.d/S10dmgtd" (and "/etc/rc3.d/S93ipm")
- reboot your box again
08-05-2005 06:47 PM
Any error messages in /var/adm/CSCOpx/log/daemons.log ?
