I have a Layer 3 switch connect to a layer 2 switch, to the layer 2 switch i have phone ip and pc connect to that phone ip, now i created vlan to the pc and voice vlan to the phone ip and put the link between the L2 and L3 as a trunk and put ip in the Layer 3 switch port (which i made a routed port ) and put that ip as default gateway to the pc
My question is why i cant ping from the pc to the default gateway (by the way I can ping to the Vlan on the L2 switch)
Thank for the help :)
