PI 2,0 can't start
Attila Erdos
we get an NCS Applience with 1.3 sw, and my first thing was to upgrade it to PI 2.0. The problem is that now the ncs service can't start, and i cant open the gui webpage. If i try to start the service, it says "This may take a few minutes..." but nothing happens.
What can i do now?
Thank you for your help!
Attila Erdos
Problem solved.:
I repaired the database by "ncs db reinitdb", and after a reload the ncs service started successfully.
