PI 2.1 Discovery Job Failure
tim.braxmaier
I am running into an issue running a Discovery job in a Virtual Domain.
For testing I created two virtual domains - "Switches" and "Routers"
in the Switches and Root Virtual Domain I can discover without issues. In the Routers domain the Discovery job fails with the following message "failed to initialize DiscoveryController"
Restarting the prime did not resolve the issue.
Anyone know what is causing this issue?
Best regards,
Tim
I have the same problem, did you find a solution?
