PI 2.2.0 Converged Theme - create WLAN configuration scheduled task
Jim Crabb
I'm doing some reworking of our "guest" wireless, and I want to schedule these WLANs to disable at a certain time and re-enable at a different time.  I know exactly where to do it in the Classic Theme (Configure > Templates > Controller Template Launch Pad), but I cannot, for the life of me, find where/how to do it in the Converged Theme.  I'd like to get this figured out, since the Classic Theme has been depricated.  The table that shows the menu mapping between the two themes shows that this menu maps to Configuration > Templates > Features & Technologies, but I'm not really sure how to use that, and I can't find any decent documentation on it.  Can anyone point me to some documentation, or maybe just walk me through how/where to do this?
Jim
ramkris2
Jim,
In the converged theme, it's under:
Inventory > Network Devices > Device Type > Wireless Controller > select Controller > Configure > WLANs > Wlan Configuration
Then the scheduled task can be monitored from:
Configuration > Scheduled Configuration Task > WLAN Configuration
I've attached a couple of screenshots for your reference. Hope this helps.
Ram
ramkris2
Jim,
Ram
Awesome, that's exactly what I'm looking for.  Thanks!
