PI 2.2 - Cisco Prime Infrastructure 2.2, latest patch level.
keanej
Participant
Participant
Recently upgraded to Cisco Prime Infrastructure 2.2
I cant seem to find a way to deploy a simple config to my routers (or view archived configurations)
conf t
Aux 0
no exec
transport input telnet
transport output none
copy run start
Am I missing something ?
Everything seems to be wireless orientated. I am licensed with BASE and 400 devices.
All my 304 wired devices imported correctly etc. I have all the latest patches installed.
Once last thing - I see people mentioning an 'operate' and 'design' menu
The menus visible to me are ..  (converged theme)
Dashboard / Monitor / Configuration / Inventory / Maps / Services / Reports / Administration
Have  I made a dreadful mistake and migrated to a wireless management platform when I only have wired devices ..
Any help appreciated
James
keanej
Participant
Participant
Here is the answer to my own question !
Configuration
Templates
features & technology
cli
new template
configurate terminal
line aux 0
no exec
exit
end
copy running-config startup-config
save template
Click Deploy (bottom right)
Select the subset of devices
deploy
monitor job  under ..
administration / jobs / user defined jobs.
Its 'sort of' contained in the user guide
Search for
"Cisco Prime Infrastructure Guide 2.2 User Guide"
Please note - the document is 3 days old !
Not exactly intuitive  !
Ashok Kumar
Below are steps for the same:-
Step 1. Create the CLI template, under below navigation:
Configuration > Templates > Features & Technologies > Templates > CLI Templates > CLI > Save As a New Template (name it)
Step 2. On the same page , next to Save As a New Template and Cancel button, there is Deploy button, click on Deploy to deploy the template
- Ashok
Please rate the post or mark as correct answer as it will help others looking for similar information
Recognize Your Peers
