PI 2.2 /var is full.
CCC3
Currently, our customer is using PI version 2.2.
I couldn't access the PI GUI, so /var was 100%.
To delete it, I logged in as root and used the rm command, but
The message ‘command was blocked’ was displayed and it was not deleted.
I entered the sudo command, but it was the same.
Does anyone know why?
We are aware that an upgrade is necessary for lower versions.
However, this is a customer request.
Please note.
5 Replies 5
Mark Elsen
 - Instead of sudo (singlet) use sudo -s to have a full  and or native Linux shell,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you for answer.
I also used the sudo -s command, but it was the same
‘command was blocked’ appears.
balaji.bandi
PI 2.X is quite old and its was gone from service Long back.
first i suggest to upgrade to 3.10 atleast for some better life
to clear the logs the problem you having :
Login to PI using SSH or Console
#ncs stop (this stop the PI processs)
#shell
#sudo -i
check the which folder having filled with Logs
#du -hs /var/log*
and Delete the file you looking to delete.
or make the files to zero down
#cd /var/log
#cat /dev/null > /var/log/messages
#df -hk - check the space
#exit
#ncs start - start the process and check GUI working ( worth reload also)
BB
Thanks for your reply.
I have a few questions.
1 There is no command called .shell, but there is a root command. Is this correct?
2. What is the command to delete a file?
3-1. If I upgrade my pi from 2.2 to 3.10, can I just download and install the same license pak?
3.2. If I upgrade the pi, will the compatibility of registered devices (ap, wlc) change?
(Currently, many of the APs registered on the Pi are old models.)
  >...3.2. If I upgrade the pi, will the compatibility of registered devices (ap, wlc) change?
 - That is a distinct possibility ; checkout  https://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/prime/infrastructure/3-10/supported/devices/PI310-Supported-Device-List.xlsx
                                                      Also look at column S/W Version ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
