lo.mueller
Beginner
PI 2.2 - Where to change/add a Prompt for configuration-mgmt?
Hi all,
trying to manage a NAM with PI 2.2 seems to be a bit complicating.
Fetching of config via CLI results in Error (/opt/CSCOncs/logs/inventory.log) that prompt is not User:.
As NAM-Login is: NAM-xxx.login:
PI seems to use an environment-variable called CLI_USERNAME_EXPECT, but I'm not able to find
the corresponding file to change that Envvar.
Anybody out there having change behaviour of of Login-Prompt?
Thanks for any feedback.
Lothar
1 REPLY 1
lo.mueller
Beginner
Just got hint from TAC how to manipulate Custom Device Prompts:
Administration > Settings > System Settings > Inventory
In Custom Device Prompts one can define a regex for username and Password.
