04-19-2016 06:34 AM
Customer has PI 3.0.0 and wants to upgrade to latest 3.0.3 MR.
However the Support downloads warns;
***Warning*** In case you have a need for Prime Infrastructure 3.0 Technology Package 1.0.3, install it before installing this MR.
The download for Technology Package 1.0.3 warns that PI 3.0.2 is required, but I don’t see a upgrade from PI 3.0.0 to 3.0.2 on the Support page? What am I missing?
04-19-2016 07:56 AM
They pulled 3.0.2 from general downloads area too soon. If you open a case, TAC will provide a Special File Publish to allow you to download 3.0.2. You can then install it, Tech Pack 1, and then finally 3.0.3.
Be sure to restart ncs each time you apply an individual upgrade. The GUI will advise a restart is required but allow you to skip doing so prior to applying the next patch or update. But doing so WILL break PI.
Also note that PI 3.1 will be out shortly. TBD whether they will update the Tech Pack to work directly with it.
04-20-2016 08:00 PM
FYI Cisco has restored availability of 3.0.2 to the downloads page.
https://software.cisco.com/download/release.html?mdfid=286285348&flowid=76142&softwareid=284272933&release=3.0.3&relind=AVAILABLE&rellifecycle=&reltype=latest
Also, PI 3.1 is now out.
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-1/release/notes/cpi_rn.html
