Hi there,
Just wondering if people have come across any issues when trying to manage 3850's I have some that are really well behaved and others that constantly fail to synchronise and inventory collection and SNMP time out. I have tried a few things but just wondered if anyone else had been having issues.
Cisco Prime Infrastructure
Version : 3.0.0
Build : 3.0.0.0.78
Critical Fixes:
PI 3.0.2 Update 02 ( 2.0.0 )
PI 3.0.3 ( 3.0.0 )
PI 3.0.3 Update 01 ( 1.0.0 )
Device Support:
Prime Infrastructure 3.0 Device Pack 2 ( 2.0 )
Prime Infrastructure 3.0 Device Pack 3 ( 3.0 )
Prime Infrastructure 3.0 Device Pack 5 ( 5.0 )
Prime Add-Ons:
Prime Insight Agent ( 1.0.0 )
PI 3.0 TECH PACK ( 1.0.3 )
I have shelled onto the prime box and can seem to use SNMP ok from the CLI.
ade # snmpwalk -v 2c -c testrwrw <ip> system.sysName.0
Cannot find module (ENTITY-MIB): At line 0 in (none)
SNMPv2-MIB::sysName.0 = STRING: SYSTEMNAME
ade #
However I sometimes get this
Timeout: No Response from <ip>
So I am wondering if its a bug with the 3850 SNMP implementation but I have other 3850's working fine though so there seems to be no common thread.
Are the ones that work and don't work on the same ios-xe version and same platform model
I have a lot of 3850s all running snmpv3 was Prime 3.0 just upgraded to 3.1 though have not had any issues with them on that version of snmp but I have had problems with both prime and ios-xe with bugs to say the least
one thing il say if you do go to 3.1 be careful as we hit an inline upgrade bug that wiped the DB all devices all credentials that were configured even all the compliance reports we had set up , lucky enough we had a snapshot backup of the VM taken just before we started ,unfortunately TAC never provided the bug ID as they weren't aware of it yet.
Maybe try snmpv3 when I checked the release notes for each prime release there seems to be a lot less snmp bugs for that version and we have not had an issue with snmp connectivity yet
We are running same version as you above for IOS-XE the safe harbour 3.6.4E
