nixpengu1n
Beginner
PI 3.3 - internalSchedule Job Issue
Hello, all
I've recently installed PI 3.3 and configured it (as much as possible) according to Admin and User Guide. However I am facing with a strange Job Scheduler issue - some job is keep failing and giving me this error:
However under Administration -> Job Dashboard I can not see any failed jobs. Everything is green or on stop. Does anyone come across such issue? My problem is - I am a bit confused where to check this job and modify / stop it (as it seems this is some internal PI job).
Thank you in advance.
10 REPLIES 10
kkolander
Beginner
Has anyone an explanation or a solution for this problem?
I see 18 people have this problem too.
meconomou
Beginner
mpofut0901
Beginner
I installed Prime Infrastructure 3.3.1 Maintenance Release file PI_3_3_1-1.0.15.ub and the issue has been resolved now:
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-3-1/release/notes/cpi_rn.html
I am experiencing this same issue as well using Cisco Prime Infrastructure 3.4 build 3.4.0.0.348.  Latest Device Pack 3.  Same issue.  Anyone able to fix their issue with this?
jegan_rajappa
Beginner
I am seeing same problem in 3.4.0.
I discovered my issue was happening due to I had a node that was not polling properly.  After I corrected the issue with the faulty node, this went away.  Recommend checking your nodes to make sure they are all polling correctly.
What change did you made in your polling config?
ferenc.vissers
Beginner
Experienced same in PI 3.4.1 and now in 3.5.
Same on version 3.8
Regards.
katerina.dardoufa
Enthusiast
is there any update on this? I am also running PI 3.8, the inventory is up to date, so there doesn't seem to be an impact on services, apart from the major alarm.
Kind regards,
Katerina
Content for Community-Ad
