PI 3.3 OnDemandReportsCleanUp failing
katerina.dardoufa
Enthusiast
Enthusiast
we recently installed Prime Infrastructure 3.3 standard edition. The OnDemandReportsCleanUp job runs every 6hours, but keeps failing. This shows up as a Major system alarm, with the message "OnDemandReportsCleanUp (cleanup):This job failed for three consecutive times"
Has anyone faced the same behavior before?
Thank you in advance,
Katerina
daniel.litwin
Beginner
Beginner
I believe it's a bug.  I had it too.
If I remember the fix was to go in and run those jobs manually once.  From then on, things are fine.
Dannon
Hello Dannon,
I ran the job manually, but it still fails.
Thank you though for the suggestion.
Katerina
