06-26-2019 01:54 AM
I have noties that several maps are showing in red indicating there is a critical alarm. But on the maps there are no critical alarms (AP down). Is this a bug?
See attached screenshot.
07-03-2019 03:01 AM
I have verified that this is indeed a bug and is related to the copy and replace function. To fix it just manually remove and add the AP to the map.
Log in to Community
