11-26-2022 08:09 PM - edited 11-27-2022 05:29 AM
I'm configuring the OSPF network, and I got some problems.
In the picture file given, the PC-A could ping the R3 using the 10.40.40.2, but it could not ping the network (192.168.30.0), and vice versa.
May I know what is happening on these networks?
Thanks in advance.
11-27-2022 02:31 AM
I dont see picture yet. You can attach PT file here but must be zip format.
Regards, ML
**Please Rate All Helpful Responses **
11-27-2022 05:29 AM
Sorry. I've edited it.
11-27-2022 07:08 AM - edited 11-27-2022 07:55 AM
Hi @Louis Lee ,
Try removing the static route for 192.168.30.0/24 on R1 and try pinging 192.168.30.1 and 192.168.30.3 again. Also, can you attach the PT file as @Martin L suggested.
