Pix Firewall Management Console Java error
restabrook
I've just started at a new job, and I keep getting this error when the Pix management console tries to load in my browser.(Firefox 1.0.6) Here is the error. Can someone please help?
Exception: java security AccessControlException: Access Denied (java util.Property Permission java.version.read)
I don't know where to set permissions for this.
Thanks in advance
Rick Estabrook
Network Administrator
Education Sales Management
Denver, CO
nhabib
Level 9
Level 9
What version of the Java Plug-in do you have installed?
I believe 1.5 causes this kind of a problem. Make sure that you only have 1.4.2
I found the fix.. in control panel, internet options, on the advanced tab, under security, the checkbox that says "install software..." (winxp pro)has to be checked. Then the aplet will install and run.
Thanks for the reply!
Rick
