Please Help To Correct My Tree Design
Hudson86
Can someone help me to correct my design? I tried to test sending messages to 2 devices Laptop3 and Smartphone which connect to the Wireless Router all failed.
Thank you so much for your attention and participation.
post your zipped Packet Tracer project file...
12 Replies 12
marce1000
       - FYI : Community group for Packet Tracer project questions
 M.
Hi Georg, I tried to upload the file but it said that the file type pkt wasn't supported.So I don't know how to post it
MichaelMcCoy
@Hudson86 you will have to zip (compress) the file before uploading.  The file extension that you recieve after that will be .zip and should be able to be uploaded.
Hi Michael, I just tried and now it says the file type .zip was also supported.
Or maybe my file size is 428KB more than 70KB its required.
The file size should be fine, I believe you may have misread but I am seeing that 70 MB is the maximum, so a file of 428 KB should be perfect.
I already compressed it to a file zip. And it still says not supported file zip.
I already posted. Could u plz help me check it out?
Thank u so much
Hudson86
I opened your network file. The problem is that the wireless router has the same IP address on the LAN side as the rest of your network. This won't work, you need another subnet (other than the 192.168.86.0 network) on the LAN side. I changed it to 192.168.85.0, but I do not know what the requirements are for this project ?
Attached the revised file...
Hi Georp, thank u so much for ur help.
I just need it for my uni assignment. And I still wondering how can I test the IP phone and Smartphone if it works.
in the revised file, you should be able to ping the smartphone and the laptop with their new IP addresses. Is that enough for connectivity, or are they asking for more ?
