Port 500 refusing connection on RV320
Deddo
Beginner
Beginner
After configuring an IPSec gateway to gateway of RV320, phase 1 has refused to go through, error from the connecting device PFsense shows that port 500 refused the connection.
My understanding is that port 500 is opened by default on RV320, why is it now refusing connection?
Deddo
Beginner
Beginner
This is my configuration on both sides
Interface:
WAN1
Keying Mode:
IKE with Preshared key
Enable:
Local Group Setup
Local Security Gateway Type:
IP Only
IP Address:        41.
Local Security Group Type:
Subnet
IP Address:
192.168.1.0
Subnet Mask:
255.255.255.0
Remote Group Setup
Remote Security Gateway Type:
IP Only
IP Address
102.
Remote Security Group Type:
Subnet
IP Address:
192.168.2.0
Subnet Mask:
255.255.255.0
IPSec Setup
Phase 1 DH Group:
Group 2 - 1024 bit
Phase 1 Encryption:
AES-256
Phase 1 Authentication:
SHA1
Phase 1 SA Lifetime:
28800
sec( Range: 120-86400, Default: 28800 )
Perfect Forward Secrecy:
Phase 2 DH Group:
Group 2 - 1024 bit
Phase 2 Encryption:
AES-256
Phase 2 Authentication:
SHA1
Phase 2 SA Lifetime:
3600
sec( Range: 120-28800, Default: 3600 )
Minimum Preshared Key Complexity:     Enable
Preshared Key:
Preshared Key Strength Meter:
Keep-Alive, NetBIOS Broadcast and Dead Peer Detection Interval enabled under advanced
and for the process log it shows port 500 is listening on my public IP
Do not understand what the problem might be
