PPPoE over VLAN configuration
Gregorygrzegorz
Hey there,
I have Cisco ISR 900 device. I'm trying to pass traffic from my vlan 10 via dialer 1(ppoe client).
When i tested ping from dialer 1 it works but i can not combine dialer and vlan.
Can anyone see what i'm doing wrong?
Config in spoiler:
Spoiler
Building configuration...
Current configuration : 2637 bytes
! Last configuration change at
version 15.8
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 10.0.0.0 10.0.0.50
ip dhcp pool LAN
import all
network 10.0.0.0 255.255.255.0
default-router 10.0.0.254
dns-server 172.64.36.1 172.64.36.2
lease 0 1
ip name-server 172.64.36.1
ip name-server 172.64.36.2
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
license udi pid C921-4P sn xxxxxxxx
username xxxxxx privilege 15 secret 5 $xxxxxxxxxxxx
redundancy
interface GigabitEthernet0
description Lan connection
switchport access vlan 10
no ip address
interface GigabitEthernet4
description PrimaryWANDesc_internet connection
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet5
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan10
description Vlan 10
ip address 10.0.0.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Dialer0
no ip address
interface Dialer1
mtu 1480
ip address negotiated
ip mtu 1480
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1412
dialer pool 1
dialer-group 1
ppp mtu adaptive
ppp authentication chap callin
ppp chap hostname xxxx
ppp chap password 0 xxxx
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
access-list 1 permit any
control-plane
line con 0
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
Thanks in advance for help
you can also try the below (changes marked in bold
version 15.8
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool LAN
import all
lease 0 1
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
redundancy
no ip address
no ip address
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan10
description Vlan 10
ip nat inside
interface Dialer0
no ip address
interface Dialer1
mtu 1480
ip mtu 1480
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp mtu adaptive
ip http server
--> ip nat inside source list 1 interface Dialer1 overload
--> access-list 1 permit 10.0.0.0 0.0.0.255
control-plane
line con 0
line vty 0 4
login
end
sorry I dont see attach config
as @balaji.bandi  mention you need NAT overload,
if not success
share
show ip route
balaji.bandi
add below line and test it.
access-list 100 permit 10.0.0.0 0.0.0.255 any
ip nat inside source list 100 interface Dialer1 overload
Note : dns-server 172.64.36.1 172.64.36.2  ( if this is valid DNS ok, if not change to 8.8.8.8 google DNS if browsing not working)
BB
version 15.8
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool LAN
import all
lease 0 1
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
redundancy
no ip address
no ip address
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan10
description Vlan 10
ip nat inside
interface Dialer0
no ip address
interface Dialer1
mtu 1480
ip mtu 1480
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp mtu adaptive
ip http server
control-plane
line con 0
line vty 0 4
login
end
It works thank you very much
