11-02-2018 07:35 AM - edited 11-02-2018 07:41 AM
Hello guys
what's wrong with my configuration i get connected to the VPN client but there is not internet connection
Building configuration...
Current configuration : 3654 bytes
version 12.4
service tcp-keepalives-in
service tcp-keepalives-out
hostname GOLDANCPE1
boot-start-marker
boot system flash:c1841-advipservicesk9-mz.124-9.T4.bin
boot-end-marker
enable password cisco
no aaa new-model
resource policy
memory-size iomem 15
clock timezone UTC 1
clock summer-time UTC recurring last Sun Mar 2:00 last Sun Oct 3:00
ip cef
ip domain name cisco.com
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 200
username cisco password 0 cisco
username test password 0 test
username support password 0 support
archive
log config
hidekeys
crypto isakmp policy 12
authentication pre-share
group 2
crypto isakmp key g01d3ng45 address 91.81.223.244
crypto isakmp key g01d3ng45 address 91.81.223.245
crypto ipsec transform-set GOLDANCPE1 esp-des esp-sha-hmac
crypto map cdalight 12 ipsec-isakmp
set peer 91.81.223.244
set peer 91.81.223.245
set transform-set GOLDANCPE1
match address 102
interface FastEthernet0/0
description FE verso core network
ip address 172.24.215.5 255.255.255.0
no ip route-cache cef
no ip route-cache
speed 100
full-duplex
standby 0 ip 172.24.215.7
standby 0 preempt
standby 0 name gruppo1
standby 0 track FastEthernet0/1
crypto map cdalight redundancy gruppo1
interface FastEthernet0/1
description Link verso LAN
ip address 192.168.1.13 255.255.255.0
speed 100
full-duplex
standby 0 ip 192.168.1.14
standby 0 preempt
standby 0 name gruppo2
standby 0 track FastEthernet0/0
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Virtual-Template200
ip unnumbered FastEthernet0/1
peer default ip address pool pptp-pool
no keepalive
ppp authentication chap auto
ip local pool pptp-pool 192.168.0.50 192.168.0.60
ip route 0.0.0.0 0.0.0.0 172.24.215.1
ip route 83.224.65.188 255.255.255.255 172.24.215.1
ip route 83.224.65.189 255.255.255.255 172.24.215.1
ip route 83.224.94.56 255.255.255.248 172.24.215.1
ip route 91.80.47.80 255.255.255.248 172.24.215.1
ip route 91.81.223.240 255.255.255.255 172.24.215.1
ip route 91.81.223.241 255.255.255.255 172.24.215.1
ip route 91.81.223.244 255.255.255.255 172.24.215.1
ip route 91.81.223.245 255.255.255.255 172.24.215.1
ip http server
no ip http secure-server
access-list 77 permit 192.168.50.0 0.0.0.255
access-list 102 permit ip any 172.24.232.0 0.0.0.127
access-list 102 permit ip any 91.80.47.80 0.0.0.7
access-list 102 permit ip any 83.224.94.56 0.0.0.7
access-list 102 permit ip any 172.24.232.128 0.0.0.127
access-list 102 permit ip any 172.24.215.0 0.0.0.255
access-list 123 permit tcp any host 2.228.69.138 eq 1723
access-list 123 permit gre any any
snmp-server community anonymous RW
control-plane
banner motd ^CCCCCCC
This device is property of VODAFONE-OMNITEL
Access at this equipment is allowed only VODAFONE-OMNITEL authorized personel
Unauthorized use is proibited
* Cliente Goldengas
* Apparato: Cisco 1841
* Servizio CDA light - NO GRE
^C
line con 0
password cisco
login
line aux 0
password cisco
login
line vty 0 4
exec-timeout 30 0
password cisco123
login local
line vty 5 15
password cisco123
login
scheduler allocate 20000 1000
end
11-02-2018 03:19 PM
you are point to default gateway
172.24.215.1
check do you have any NAT or allowed rule for your VPN pool
