PPTP
operatorze
HI
I hava Problem with c831
How can i config it for connection to a ADSL over pptp
Thank a lot
oze
umedryk
Level 5
Level 5
You can go to www.cisco.com/techsupport/-------> click on Products ----------> Routers -----------> Fixed config ruoters ---------> select the model and click on view all documents and you will find some configuration examples
