Beginner
Prime 2.2 Power supply alarms
doing some testing in a new data centre with Prime 2.2 and wondering if there is a way to be immediately notified in the event I lose a power supply or a fan.
I thought I had all the monitoring turned on but when I pulled a power supply I had to re-sync the device before Prime knew about it and then it still never notfied me.
3 REPLIES 3
Hall of Fame Master
Have you enabled email
Have you enabled email settings for critical alerts on switches and routers?
Beginner
yes.  I see when a router
yes.  I see when a router goes down.  I get an email.  But not when the power supply is unplugged
Beginner
heyi have issue aswell to get
hey
i have issue aswell to get snmp poll working optimal so atm in pi i am working more on snmp trap and syslog as the way to get the notification.
snmp-server trap-source [interface]
snmp-server host [pi-ip] (vrf [vrf name]) version 2c [community string]
snmp-server enable traps envmon supply
secend minor issue is pi only set this a minor error so if you treshold on email notification is set to  critical you wil never get and email alarm so if that is a must you must edit the servirity og the alarm og send warning email as well
Content for Community-Ad
July's Community Spotlight Awards
