Prime 3.1.4 Export Devices (all) not working
h.cloostermans
I'm trying to export a list of all devices with their credentials (Inventory > Device Management > Network Devices, select all devices & Export Device).
This works fine for just a couple of devices, but when selecting all of them (more than 3500), the export fails half way or doesn't even start.
And when I select just the routers for example (+/-1870), the csv file stops at +/- 1800 lines.
Has anyone else encountered this problem ? Is this a bug ? Or is it just me ? :-)
Helen
sekhabbaz
I thought i have this problem to (3.3.0). But it seems it just takes 20-30 minutes for the 20kb-something file to be generated.
dehartyz1
Why only 1000!
